Earth tube cooling: Why not clay/concrete pipes? | 7 comments (7 topical, editorial)
Re: Earth tube cooling: Why not clay/ (3.00 / 0) (#5)
by fcfcfc on Thu Mar 6th, 2008 at 07:48:08 PM MST
Hi: I have mine that I just put in for my new storage building, I used 12 - 100' lengths of 6" PVC flex drain pipe. The pipes all run in parallel. This summer will be the first. I plan on hanging 3" dia chlorine tablets at the air inlet and put enough tablets in to make the incoming air at about the same level that you get around a YMCA pool. The air goes in and out, no recirc.. If that doesn't work or seems un necessary, I will just flush them going into Summer and leaving Summer with a Clorox solution... Plastic is light, fairly cheap and easy to work with...
Re: Earth tube cooling: Why not clay/ (3.00 / 0) (#7)
by jtashijan (jtashijan) on Wed Jul 30th, 2008 at 10:01:35 PM MST
How has your earth tube worked out?
How did you determine how long and big your tubes would be?
John Tashijan
Earth tube cooling: Why not clay/concrete pipes? | 7 comments (7 topical, 0 editorial)
