Options for Wind-Electric Water Pumping | 53 comments (53 topical, 0 editorial)
Re: Options for Wind-Electric Water Pumping (3.00 / 0) (#7)
by Drives (drivesdeanw at yahoo.com) on Wed Mar 12th, 2008 at 09:50:30 PM MST
That last sentence should read "because you DO want to store water rather than electric power, this may be a way that does not need a VFD or batteries"
I'll go back to sleep now.  LOL
---------Dean-----------
Re: Options for Wind-Electric Water Pumping (3.00 / 0) (#8)
by cslarson on Wed Mar 12th, 2008 at 10:42:24 PM MST
Thanks for your comments. Because of your previous posts, I was hoping to get your input. I think the last solution would be ideal. The Agricultural Research Service of the USDA has done some work with this type of solution and I've included a few links below. LIke you suggested, a controller is needed to ensure a constant V/f ratio and control some on/off points for the motor. I have not found, though, any controller like this that is commercially available. I did get part way into developing my own, but have since taken a break from it to finish the prototype 4-meter wind turbine (also, my electrical engineering skills are severely limited). The problem with this approach, though, is that the wind turbines we're producing are too small independently the water needed from that depth. If I were to use these turbines I would need to combine the output from a few of them.
I think we can rewire the alternators to achieve higher voltages as needed. I am interested in your #2 option (turbine>battery bank>dc bus of vfd). These would need to be deep cycle batteries? If there was a way to configure the vfd to only use the amount of power that the wind turbines were putting into the bank then maybe the expensive deep cycle batteries would not be needed. Or maybe at least not as high Ah ratings. I mean, only power the pump when power is coming in, and then, only to match (slightly under) what is coming in. How would I regulate this? I guess I had been sizing the battery bank for the pump like you might size one for any other appliance, giving sufficient Ah capacity to ensure power is provided for some time when the wind isn't blowing. But there is a large reservoir for the water. Much, much less might be spent on the batteries if the pump were only to be powered when the turbine is producing, and hopefully, somehow, to match that output. That may have been obvious to everyone else!
1996 A Smart Controller for Wind Electric Water Pumping Systems
2000 Development and Testing of a 2-Kilowatt Wind Turbine for Water Pumping
