What are the Holes For? | 20 comments (20 topical, editorial)
Re: What are the Holes For? (3.00 / 0) (#11)
by dinges on Fri Mar 14th, 2008 at 07:15:42 PM MST
"Am thinking of using my floor length drill press,"
Before you do, verify that the chuck is positively held in place with for example a retaining bolt. A plain morsecone (MK1, MK2) may be simply pulled out. Not sure what kind of joint there is on your drill.
A morsecone is designed to take up a radial load under compressive pressure. Tensile stress (as occurs during rotor insertion) may simply pull it out.
Maybe I'm stating the obvious but thought I should point it out anyway.
Peter.
Re: What are the Holes For? (3.00 / 0) (#12)
by dinges on Fri Mar 14th, 2008 at 07:49:35 PM MST
correction:
Is NOT designed to take up a radial load but a torsional moment under compressive pressure.
Peter.
Re: What are the Holes For? (3.00 / 0) (#13)
by lforbes on Sat Mar 15th, 2008 at 11:16:23 AM MST
Thanks for the caution Peter but as I mentioned, I plan on suspending the rotor by a cable over top of the head (to prevent exactly what you point out).  OTOH if the chuck is extracted, there is a slot (in the "quill"?) through which the cable cab be threaded which will allow raising or lowering the rotor from the top.
I may though use a piece of iron in the chuck to lower individual neos into place, specifically the middle row neos (each pole will have three rows).  The two outer row neos I have found can be easily placed manually.  I believe the magnetic force from one neo will not be enough to pull out the chuck (or so I will find out).
Laurie
Laurie Forbes
Calgary, Canada
What are the Holes For? | 20 comments (20 topical, 0 editorial)
