Rahai vawt anyone? | 23 comments (23 topical, editorial)
Re: Rahai vawt anyone? (3.00 / 0) (#19)
by john j on Sun Mar 16th, 2008 at 01:52:32 PM MST
Thanks Tom, Ill try and reduce
Cheers, john j
test rig turning, pics (3.00 / 0) (#22)
by john j on Fri Apr 4th, 2008 at 02:53:42 AM MST
Just got the stoneage vawt up. There will be more sets of wings to come. Just wanted to see how it reacts. It starts turning with very little wind. I tried to measure resistance in the very heavy bearing. If I measure correctly, turning of the hub and bearing takes 29 volts and 0.05 amps. Cost so far: about 100 US$
Cheers, john j
Re: test rig turning, pics (3.00 / 0) (#23)
by ghurd on Fri Apr 4th, 2008 at 07:43:19 AM MST
Probably work a lot better if the top is covered.
Just for a quick test, maybe slap a piece of 3/8" plywood on top with tarp straps?
Re: test rig turning, pics (3.00 / 0) (#24)
by john j on Sat Apr 5th, 2008 at 05:21:33 AM MST
Yes I think youre right. Only its hard to know any difference, as I dont have an alternator yet. And even then, how would you measure output? Thanks anyway.
Cheers, john j
Rahai vawt anyone? | 23 comments (23 topical, 0 editorial)
