Air gap question | 8 comments (8 topical, editorial)
Re: Air gap question (3.00 / 0) (#2)
by TheCasualTraveler (a.miklos@yahoo.com) on Fri Mar 14th, 2008 at 05:26:47 PM MST
     Cut in is about 100 RPM +or- The winds are 15 to 20 plus gusts and it's only putting out 1 to 1 and a half amps. In these winds it's not even spinning enough to make that whirring sound. Before I added the second disc it would put out 3, 4, 5 amps and more in winds like this. I don't want it to spin out of control I actually like this damping effect I would just like it to be around 5 to 600 RPM or so.
     But if the answer to my question is that it doesn't matter where the stator is in the gap then I will just start moving the second disc out till it raises cut in and speeds up some.
Andy
Re: Air gap question (3.00 / 0) (#3)
by wpowokal on Fri Mar 14th, 2008 at 10:46:11 PM MST
OK I see, apart from mechanical clearances it does not matter which side, the magnetic flux has to bridge the air gap at what point it passes through the windings of the stator is "basically" irelevent.
You need the speed for output, Ed has those magnets on special at the moment why not make it a proper duel rotor. Your origional post indicated increasing the air gap by 1/8" which is a fair bit so that should help a lot, If it was mine I would like to have both gaps even for mechanical clearances, but depending on how you have your stator mounted how easy that is to achieve.
Remember flux density is not linear with distance, for you it's a bit of a suck it and see so give it a go and gain some important data at the very least. We added 1mm to the air gap on my duel rotor for clearance reasons, and that raised the cut in from 140 to 240 rpm, maybe it would produce a tiny bit more if it was lower but I am very happy with it as is.
Oh and let us know the results.
allan down under
Re: Air gap question (3.00 / 0) (#4)
by Flux on Sat Mar 15th, 2008 at 02:41:57 AM MST
I don't have the details of your winding but I am fairly sure you have lots of turns of thin wire. Now you have improved the magnetic circuit you have hit stall. You would do far better to raise the cut in speed by reducing the number of turns or connecting in delta or Jerry connecting it.
If you just increase the air gap you will be back close to where you were before and the thin wire with high resistance will still be a limitation. You may get some sort of compromise that is better than before but you will not gain the full potential.
Regarding the air gap on this set up with magnets on one rotor and not on the other, it is largely the total gap that matters  but you will see more increase in speed with the stator nearer the blank disc compared with it near the magnet disc. You need to make coarse adjustments with the total gap but you can get fine adjustment by altering the stator position.
If this is a 12v system, before you make any changes try running it temporarily into 24v if you can find a spare battery. You will likely get far more power with the present winding.
Air gap question | 8 comments (8 topical, 0 editorial)
