LED light for Fiji 2008 Completed | 9 comments (9 topical, editorial)
Re: LED light for Fiji 2008 Completed (3.00 / 0) (#1)
by commanda (alwynne at unwired dot com dot au) on Fri Mar 14th, 2008 at 01:23:24 AM MST
Absolutely beautiful Rich. I congratulate you on your workmanship.
My only suggestion is liberal use of a conformal coating on the boards, after masking off the leds themselves. Help prevent corrosion from the humidity  and salt air.
Re: LED light for Fiji 2008 Completed (3.00 / 0) (#4)
by richhagen (richhagen (a t) Juno.com) on Sat Mar 15th, 2008 at 12:48:01 PM MST
Thanks, I ordered up a silicone based spray on conformal coating.  If it arrives before I have to have these dropped off for shipping then I can get them coated.  If it does not, I will likely be out of luck as I don't think I can ship that to Fiji.  Rich
Re: LED light for Fiji 2008 Completed (3.00 / 0) (#9)
by richhagen (richhagen (a t) Juno.com) on Thu Apr 3rd, 2008 at 04:54:48 PM MST
I was able to spray them down inside and out with a silicon based conformal coating.  I put pieces of electrical tape over the LED lenses during the process.  Rich
LED light for Fiji 2008 Completed | 9 comments (9 topical, 0 editorial)
