inverter double wound transfromer overheating | 6 comments (6 topical, editorial)
Re: inverter double wound transfromer overheating (3.00 / 0) (#4)
by donald77777 (donald7_44@hotmail.com) on Sun Mar 16th, 2008 at 11:52:18 PM MST
I may not be reading this right however, you say the inverter is cutting out from heat. Wouldn't a fan help your situation? Disconnect the inverter pull off the top if not in warranty, cut out an 80 mm fan hole. Attach a fan.
inverter double wound transfromer overheating | 6 comments (6 topical, 0 editorial)
