Volvo Farmer
I'd have stuck fairly close to this so using those figures it would be 20mA per series x 7, which comes to 140mA at the light but there will be some loss at the regulator too. The regulator sees anything between 12 and 15v and loses more as heat as the voltage rises."Slowly changing the world, one watt at a time!"[ Parent ]
That should be: 'It is only now, the highest of efficient LED's that can rival flourescent lighting in overall visible light output efficiency.''A Joule saved is a Joule made'[ Parent ]
At 140ma and 12.6V that's 1.75W. If it makes enough light for the situation, great!
If the power available is under a couple hundred ma, or if the situation only needs a little light, LEDs still beat CFLs.
The smallest, common, good quality, 12VDC CFL is the 7W Solsum, pulling 660ma. It's output is totally and completely dismal compared to the same 11W pulling about 900ma. So poor, it is not worth trying to save the 250ma. That might be why most stores don't carry the 7W version.
There are a few 12VDC CFLs at a lower wattage (1W, 3W and ?) but the light they make could be easily beat with good 5mm LEDs using less amps. The tiny CFLs have to be seen in person to understand how bad they are.
I hope it's being driven at about 125ma for longer life than 140ma. Plus the efficiency goes up! G- [ Parent ]
I found this chart which is a bit interesting: http://www.mge.com/home/appliances/lighting/comparison.htm
I also found that Cree has tested LED's to 131 Lumens per Watt at least, and one can buy production LED's at 100+ lumens per Watt right now. They would be too bright to look at directly as the 80 to 86 Lumen/Watt LED's I have are and they put out less light. http://www.fieldlines.com/story/2008/3/14/55046/0695'A Joule saved is a Joule made'[ Parent ]
