cut in speed. | 4 comments (4 topical, editorial)
Re: cut in speed. (3.00 / 0) (#2)
by blueyonder (windwoodgood at yahoo dot co dot uk) on Fri Mar 21st, 2008 at 08:29:22 AM MST
 thank you flux.
    i was getting a bit down as i wasent sure as to what i was doing.
  but now you have filled me with incentive.
  what i have been doing was going ok but i was starting to drag my heels.
  the further i was getting into the unknown.
  so your answer was just right. its got all the information i needed  .
   i asked about amps.  so i dont need to go that way on a test coil.good.
  for sum reason i was thinking that the 14awg might be to thick.
   i never thought it could be a bit heavier.
   just a bit doughty. about it all.
  but you have cleared it all up.
   you have also left things a bit open to let me choose for wind speed .
   today the trees are bending.
   but its not every day the wind is so strong.
   spring is in the air and i must go do sum work on my mill.
   but with my new found incentive it will be much more enjoyable.
  it looks like i am on my way to building a little worker.
   thanks again flux and also to the forum.
cut in speed. | 4 comments (4 topical, 0 editorial)
