Fuses | 4 comments (4 topical, editorial)
Re: Fuses (3.00 / 0) (#2)
by rippersoftware on Thu Mar 20th, 2008 at 08:46:23 AM MST
Most of the 12V automotive plug type (ATC) fuses are rated to about 30VDC.  That allows for some voltage surge.  The amp rating is what the fuse should blow at.  Use the 12VDC ATC fuses and you shouldn't have any problems.
Dave in Iowa.
Fuses | 4 comments (4 topical, 0 editorial)
