The other way is to convert the motor by adding permanent magnets ( look at motor conversions here). Again the standard winding will not conveniently lend itself to 12v at the speed you will be running. You will have to do a lot of serious re connecting or go the transformer route again.
If you decide to go the motor conversion route from the start, are you stuck with 12v?
Flux[ Parent ]
If a higher than 12V system is selected, wiring costs and losses will be lower. 24V and 48V systems are far more practical than 12V for all but the most primitive electrical systems.
Ron Adventure is just bad planning." -- Roald Amundsen [ Parent ]
