Engine Driven washing machine | 16 comments (16 topical, editorial)
Re: Engine Driven washing machine (3.00 / 0) (#9)
by dinges on Sun Mar 23rd, 2008 at 05:07:04 AM MST
Many years ago there was a television series aired over here called 'The secret life of machines'. One episode was about the topic of washing machines. All shows are available for free viewing and download on their website:
http://www.exploratorium.edu/ronh/SLOM/
(Just checked, apparently you can no longer download, only view streaming video. Pity, it was one of the best televised programs I've ever seen; glad I've downloaded them all back when it was still possible and burned to a DVD... Most are available on youtube but the one dealing with washing machines isn't.)
It also goes into the history of washing machines and how they function. I think it's worth 25 minutes of your time to watch it :) One issue that comes to mind is that the motor has to spin backwards and forwards, to prevent the clothes from tangling up.
Not really a direct answer to your question but it should give you a quick overview of the different things that have been tried before we arrived at the current, 'normal', washing machine. And much more entertaining than reading dozens of old patents :)
Peter.
Re: Engine Driven washing machine (3.00 / 0) (#10)
by dinges on Sun Mar 23rd, 2008 at 05:11:07 AM MST
Fortunately... Still all available for download... Why do I always find out about this -one- minutes after posting...
http://sciencezero.4hv.org/tslom.htm
Peter.
Re: Engine Driven washing machine (3.00 / 0) (#13)
by nick1234 on Sun Mar 23rd, 2008 at 10:16:06 PM MST
had an older fellow than i living up farther up the mountian from me he had a ringer washer that he was useing on a water wheel to drive it  had problums i sugested to add a flywheel from a hay bayler and hand start it  following week he found one installed  it and thank me for the advice it worked till he move away
nick
qc. ca.
Re: Engine Driven washing machine (3.00 / 0) (#14)
by vantravlers7 (vantravlers@aol.com) on Mon Mar 24th, 2008 at 01:32:56 AM MST
There are wringer washers laying all over the woods here... that is not what I had in mind.  Im sure the Mrs would not favor the wringer washer either.  Ideally, I would have two side by side washers that run off the same power source at once.  I am talking about washing for SIX people, three of whom are under 4 (hence collect dirt).  Small loads of laundry are not what we do.
   I am almost sure the washer I had in mind externally looked like a "normal" washing machine.  Seems like the rear panel was removed, and they had a gas engine back there/ off to the side.
   Used washers that have a burned up motor: free.  Used washers that still run: cheap enough.  So running the gennie is not out of the question, but there isn't alot of room for advancement in running it RE.  I get the point about electric motors being a "good" way to run the washer, tho.
Re: Engine Driven washing machine (3.00 / 0) (#15)
by zeusmorg on Mon Mar 24th, 2008 at 08:18:31 AM MST
  The problems you'd encounter in attempting to convert an a/c modern washer to run off a d/c motor or other source such as a water wheel are numerous. First off, all the control mechanisms are a/c such as the water valves, timers etc. So i just don't see how you would practically convert it all over.
  Your best bet is to buy the most efficient electric washer and run it off a good sine wave inverter or sine wave generator. Some of the front load models available today are stingy with both water and electric usage. I would think it would be better and probably cheaper in the long run overall to generate electricity with whatever power source you can come up with and then use that to run a washing machine.
  Of course dryers are a totally different story! They are energy hogs and a good old fashioned clothesline is yet to be beat in energy consumption.
Engine Driven washing machine | 16 comments (16 topical, 0 editorial)
