Ready to measure! | 6 comments (6 topical, editorial)
Re: Ready to measure! (3.00 / 0) (#3)
by frackers (g8ecj at *nospam* gilks dot org) on Fri Mar 28th, 2008 at 05:44:33 AM MST
I like that a lot!! Sure I've seen it before (either on your site or somewhere else recently). Question is, how do I do it!
I'm running a Linux box with apache/php/perl/mysql - the usual lamp stuff in fact. All the weather stuff is using the rrdtools package with the cacti wrapper and the raw data comes from a LaCrosse 2310 weather station so I can massage it in many ways even if I can't integrate that particular display into the cacti stuff (but I could put it into the static exported page)
All donations of (GPL) code gratefully received :-)
Re: Ready to measure! (3.00 / 0) (#4)
by rossw on Fri Mar 28th, 2008 at 01:28:23 PM MST
(User Info) http://house.albury.net.au/
Ahh, thats excellent.
I'm a FreeBSD man myself, but I'm sure that without too much tinkering you can get my code working on your system.
Do you have gd installed? If not, grab it and install it and give me a whistle. My code uses gd to actually create the image.
Basically all I do is take raw wind samples (in my case, every 5 seconds), take the direction to calculate the start and end of the arc, and the speed to make the radius.
Perhaps the hardest part is the time calculations, I scale over 1, 4 or 24 hours so the colour scale smoothly transitions over the period. Depending on where the current sample is in the time domain determines what colour I draw the arc.
Draw the scales, plonk some labels, write the output, done.
Are you comfortable coding in C? Can send you source. Possible I could link it static and send you executable? Not sure on that one!
R.
Re: Ready to measure! (3.00 / 0) (#5)
by frackers (g8ecj at *nospam* gilks dot org) on Fri Mar 28th, 2008 at 09:49:50 PM MST
I'm quite comfortable coding in C - it has paid the mortgage for the last 20 years after all - so the source would be great. I already have gd-2.0.35 installed (on checking I see that Gallery, php and graphviz have dependancies on it).
As if I didn't have enough to do...
Re: Ready to measure! (3.00 / 0) (#6)
by rossw on Fri Mar 28th, 2008 at 10:22:29 PM MST
Check your e-mail.
I've sent you the source of my code, along with some sample shell scripts to show you how I use it, and a snippet of my raw log so you know what it's expecting!
The code is for your own, non-commercial use only, thankyou.
Ready to measure! | 6 comments (6 topical, 0 editorial)
