March 24 2008 | 20 comments (20 topical, editorial)
Re: March 24 2008 (3.00 / 0) (#7)
by jmk on Mon Mar 24th, 2008 at 05:35:23 PM MST
 Well, if he is rideing everyone will know where he is at. At the least you know when he is coming and leaving.
jmk
Re: March 24 2008 (3.00 / 0) (#8)
by JW on Mon Mar 24th, 2008 at 06:20:07 PM MST
DanB,
 Did the hub feature a 'rear-seal', from here, it looks like the weather may have washed it out. I know the spring loaded hub seals can make it tough to R&R hub assys and make it difficult to re-pack the rear bearing. I always use great care when I encountor one on a hub. Most of the time its gotta be replaced, because they can be rough to remove(when there rusty, etc).
 As for that phono-graph loudspeaker, on the motorcycle, it must have been around in the time of Thomas Edison. Looks pretty sturdy, I dont see a braket. Although, one of those Conquistador helmets would go perfectly with that.  :)
JW
March 24 2008 | 20 comments (20 topical, 0 editorial)
