changes in vane axial turbine design for free flow wind turbine vs wind turbine | 7 comments (7 topical, editorial)
I meant horizontally rotating (3.00 / 0) (#3)
by NukeManSoon on Tue Mar 25th, 2008 at 08:24:54 PM MST
I meant a turbine that rotates horizontally. I was just wondering maybe some angles of the blades for low speed water turbine maybe a 3-4 mph stream of water.
Re: I meant horizontally rotating (3.00 / 0) (#4)
by wdyasq on Tue Mar 25th, 2008 at 08:38:36 PM MST
If you are speaking of a high efficiency 'propeller', it would need to be calculated. It has the same 'problems' a wind turbine has (HVAT) of twist and such.
If you are truly interested look up those from "HPV" - human powered vehicles, Pay special attention to those used in watercraft.
Re: I meant horizontally rotating (3.00 / 0) (#6)
by DanG on Tue Mar 25th, 2008 at 09:37:07 PM MST
Propulsor would be a good keyword to explore.
changes in vane axial turbine design for free flow wind turbine vs wind turbine | 7 comments (7 topical, 0 editorial)
