vawt, a curious phenomenon | 20 comments (20 topical, editorial)
Re: vawt, a curious phenomenon (3.00 / 0) (#19)
by thefinis (thefinis@hotmail.com) on Fri Mar 28th, 2008 at 08:42:28 PM MST
One problem/advantage with vawts is that there are so many types out there. H rotor, S  rotor, eggbeater, helix, combo designs lift/drag like a lenz or a high lift H rotor with a drag S rotor starter. A hawt has many versions too but most are lift based. A turbine needs to fit your needs, skills, and materials available. As Gizmo pointed out many folks when looking around feel that the vawt is the easiest to build but weight, materials, reality and rpm matching tend to slow the builders to a point that many never finish. This may hold true for hawt builders too as they work towards a finished product goal.
Personally I have made many vawt turbines but never made one that I was willing to hook up to make electric power yet. Most either didn't make enough power to follow through on or were constructed for testing and were not sturdy enough to attach to a suitable generator and transmission. I did find that while vawts work in gusty turbulent flow the power seemed to be reduced by more than I expected. Wind speed cubed bites on extracting power as average wind speed drops. You have to get above the trees. The next project is to put some up on a tower in cleaner air.
Finis
Texas born and bred
vawt, a curious phenomenon | 20 comments (20 topical, 0 editorial)
