vawt, a curious phenomenon | 20 comments (20 topical, editorial)
Re: vawt, a curious phenomenon (3.00 / 0) (#7)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Thu Mar 27th, 2008 at 03:28:13 PM MST
From what I've seen here on the board, even back when there was ton of interest in the 3 bladed VAWT; I believe I even remarked back then that it looked like a set of duck heads :-] while looking down at the paper printout, that they are actually an easy way for people who are looking to copy the successes that Mother Earth News had back in the 70 ~ 80s.
Using big metal drums and welding stuff you could put one up that will indeed work, however, there's the space that it needs to be up for anything that can be a constant source of charging. M.E.N. did that with no problems.
Now, though , there is the need to get as much out of what you can as possible. The early Otherpower forum had lots of stuff using the ceramic magnets , now since the newer ones work so much better those hardly get any mention, but are still good .
Once someone gets their feet wet form trying or completing one and then get "hooked" on the POWER :-) they normally jump to the more powerful HAWTs.
Curiously enough, the city, in an area like where I live, are more likely to allow VAWTs, like the one fungus has up than they would a HAWT any day.
VAWTs are normally slow moving and are there for looked at as Lawn Art or safer with less room needed to keep things safe.
For small units VAWTs look to be even easier to bulid Windstuff Ed's learner kits is a beautiful kit and a prime example.
I certainly would not count it out, have a look at Pepa's unit.
JMHO:-)
Milage my vary...
vawt, a curious phenomenon | 20 comments (20 topical, 0 editorial)
