From what I understand you to be saying, your outlet "hot" pipe is actually ABOVE the level of the water in the bath, yes?
If so, I think your "spitting" water is because you're getting local boiling in your tube.
To get a nicer flow of water, I can only see two ways: (1) Use a small pump (even a little fishtank or garden pond pump) to push water into the bottom of your coils and maintain circulation that way or (2) keep the outlet below the water surface so it can thermosyphon.
(2) might be a bit hard to achieve without drilling another hole in the bath, but you could possibly get away with using a slightly longer hose, up over the side of the bath and back under the surface. Once you bleed all the air out of the hoses and pipe, the heating of water alone SHOULD be enough to create a continuous but gentle flow.
allan down underA life lived in fear is a life half lived.[ Parent ]
thanks Joseph[ Parent ]
An expansion tank on the outlet with a top vent open to air say 3/4 - 1" , a side outlet to your tub with a shepards crook of say 1/3 height of tank will ensure your tub gets hot water not steam. Yes you will loose a little of the water from your tub as steam but possibly better than a steam burn.
Thanks for the response. I'm not sure what you are describing with the expansion tank concept. Could you give me some more details?
I have submerged the hose below the water line and this seemed to help to a degree but a constant flow did not take place. A friend suggested raising the bucket so the water did not have to travel quite so far up to the tub. This increased the amount of steam coming out but seemed to decrease the flow of water. Is this because less of the coil is below the water level? That steam makes the most amazing popping sound when it hits that cold water. I took a tub in there this morning for my pre work weekly bath. It took about 40 minutes to get the water nice and toasty which is a lot longer than I would like.
thanks for all the tips
Joseph[ Parent ]
