Have you looked at PEX for the tubing?
I have designed a zero energy home with the solar features built into the structure, cost adder is 10% above standard construction. No energy bills. Looking for someone with a workshop to test it out. don't want to build a complete home without testing the ideas.
Have fun, Scott.[ Parent ]
I only just saw this post: sorry to miss it.
I can't seem to get any consistency in U-value for papercrete. Do you think it would be better or worse than foam?
Damon[ Parent ]
Check out http://www.livinginpaper.com/index.htm
Papercrete R2 to R3 per inch, depends on the mix. (how much sand, concrete etc) Foam is R5 to R7 per inch, with a cost of $4 to $6 per cubic foot. I can get 5 tons of paper for free, the Portland cement will cost (?), I saw a 80lb bag for $6 last year.
The papercrete is so much cheaper, use twice the thickness to get the same value or more. A local recycle center will not take foams without a recycle label on it. You could request some and grind it up adding it to the mix for greater R value if important to keep walls below a certain thickness. Many things you can do, let us know what you have in mind. Glad to help.
Thanks for the link! Will read shortly.
Space is a huge constraint for me, but I know that I'm going to need a mix of materials in any case if I do it.
The thing is, by my estimate, I need amazing insulation since I would need to try to keep losses from the tank at or below ~10W (yes, ten Watts, not W/K or kW or 'what'ever) even with an outside temperature of ~10C to retain most of the heat between seasons.
Digging a cellar under our porch at the front of the house is looking like one solution providing that the local maze of drains/sewers doesn't pass under it.
To hit 10w for any tank of size is impractical. Vacuum insulating panes might do it. Very costly.
Retaining heat between seasons look into ground source storage. Dry well, store the heat in the ground, large area can store huge amounts of energy. This is my plan for driveway heating, store the heat below. Bring heat up when it snows.
In another area store the cold from winter for use in summer cooling. Or do like the pioneers did, ICE house, even thin insulation in ground a large block if ICE can run your fridge and AC all summer long.
However, I had a slight brainwave. Instead of a 5t tank losing 10W (10% loss of stored heat over 6 months), why not use a 10t tank losing ~100W (~50% loss of stored heat over 6 months)? The extra energy to put in the tank is readily available in the summer, and I need only ~10% of the insulation, ie something like 50cm instead of 5m+.
The downside is that we'd definitely need to dig down to accommodate a large enough tank as we just don't have lots of ground space. But we might not have to dig much.
