Excess DHW heat to generate electricity | 34 comments (34 topical, 0 editorial)
Re: Excess DHW heat to generate electricity (3.00 / 0) (#4)
by DamonHD (d@hd.org) on Sat Mar 29th, 2008 at 06:27:41 AM MST
Hi
Thanks for the Rankin Cycle clue.
Googling already!
Re: Excess DHW heat to generate electricity (3.00 / 0) (#5)
by DamonHD (d@hd.org) on Sat Mar 29th, 2008 at 07:32:38 AM MST
A smaller version of the Rankine machine in yourownpower.com looks possible in principle, and I've seen a number of other suggestions that solar thermal plus heat engine of some sort should beat solar PV in terms of overall efficiency and cost.
So perhaps a very small geothermal power unit which is designed for these sorts of temperatures and low-delta-Ts might be the most practical to avoid much re-engineering.
