Star confiuration | 25 comments (25 topical, editorial)
Re: Star confiuration (3.00 / 0) (#6)
by dinges on Tue Mar 4th, 2008 at 10:46:02 AM MST
My mistake.
Just -after- posting I noticed the above image applies only to two-speed motors, not the common induction induction motor.
Peter.
Re: Star confiuration (3.00 / 0) (#7)
by Flux on Tue Mar 4th, 2008 at 11:10:18 AM MST
In theory you can use a pole change as the basic problem is a machine that wants to run at constant speed connected to a power source that wants to raise its rotational speed with wind speed.
Large commercial machines often used two motors with different pole numbers. The snag is that pole change motors are something of a compromise and are costly. The changeover switches puts a star/delta change into the shade and people here don't even seem capable of contemplating even that.
Re: Star confiuration (3.00 / 0) (#8)
by dinges on Tue Mar 4th, 2008 at 11:52:54 AM MST
"puts a star/delta change into the shade"
You mean w.r.t. performance or complication of building/switchover?
Peter.
Re: Star confiuration (3.00 / 0) (#9)
by Flux on Tue Mar 4th, 2008 at 12:04:06 PM MST
Switch complication.
Re: Star confiuration (3.00 / 0) (#11)
by mbeland on Tue Mar 4th, 2008 at 01:10:08 PM MST
Please tell me why would this be so complicated?
Could the mill be by default in the best position for low wind output. Then above a given amperage, relays could be activated to switch configuration for as long as you get enough output?
Martin
Eau, soleil, le vent
Re: Star confiuration (3.00 / 0) (#12)
by dinges on Tue Mar 4th, 2008 at 01:26:45 PM MST
That's the idea, Martin.
But from Flux's reply I understand that the switch-over for dual-speed motors is complicated. I tried googling the web for suitable wiring and switching diagrams but couldn't find any.
Below is a drawing I made a few weeks ago for star/delta switchover using contactors. It needs 3, but K1 is not part of the actual star/delta switching; it's a fail-safe which always shorts output unless positively energized. As you can see, just for simple star/delta switching it takes 3 contactors (well, ok, just two for the actual star/delta).
The generator will also need a tacho-sensor (not shown in this partial schematic) and some electronics to actually energize the contactors. Not rocket science but more complicated than just hardwiring for either star or delta.
Also, it would mean running 6 wires down the tower. Or one would have to install the contactors and rectifiers at the top, but then it would still need a few wires to control the contactors. When using sliprings it would take 6...
Peter.
(K1 & K2 are normally closed (NC) contactors, K3 is normally open (NO)
Re: Star confiuration (3.00 / 0) (#13)
by joestue on Tue Mar 4th, 2008 at 03:13:48 PM MST
Why is it not acceptable to install the diodes and the relays at the top of the tower.
Why can't you epoxy or conformal coat the entire box and achieve reliable operation.
It seems the money saved in 4 lengths of wires should make up for the extra effort.
Re: Star confiuration (3.00 / 0) (#14)
by dinges on Tue Mar 4th, 2008 at 03:30:30 PM MST
I never stated it was unacceptable.
Just that it would still need several control lines (to control the contactors) running down the tower, along with the DC + and - lines.
For ease of maintenance and repair I'd like to have the contactors and rectifiers on ground level though.
Peter.
Re: Star confiuration (3.00 / 0) (#15)
by oztules (oztules__at__bigpond.com) on Tue Mar 4th, 2008 at 03:45:52 PM MST
Dinges,
 For AC induction motors, the speed change is usually done by changing from normal pole config, to consequent pole config, thus doubling the number of apparent poles, and halving the revs.
The rotor is in this case happy to go along with the pole change... in fact a three phase and single phase 4pole, 2pole rotor is the same animal and depending on what forces are operating on it, decides the pole no (bit hazy about this ).
Your conversion rotor is static in its pole spacing and coverage area, so I'm not sure how this would work if at all.
Should work for an induction motor acting as a genny, (with exciter caps) but???? for a conversion.
.........oztules
Re: Star confiuration (3.00 / 0) (#18)
by Flux on Wed Mar 5th, 2008 at 12:47:37 AM MST
At the risk of continuing the hijack and Tom's anger. I have to admit that I didn't think this through when I suggested you may be able to adopt a pole change.
Oz is correct, this can only work on a cage rotor, it just doesn't work with permanent magnet rotors. Anyway it was a bit tongue in cheek as the complexity is beyond anything reasonable.
Re: Star confiuration (3.00 / 0) (#22)
by mbeland on Wed Mar 5th, 2008 at 03:15:12 PM MST
Thanks Peter for the schematics,
I understand you would have to run 6 wires instead of 3 if the rectifiers are down the tower or instead of 2 if they are up but couldn't these wires be smaller since each of them takes less current?
Also, instead of having a tacho sensor with wires up and down the tower, couldn't it be simply some device to measure the output from the mill (I guess in current would be best) and trigger the contactors above a given current value?
Thanks for helping me understand,
Martin
eau, soleil, le vent
Re: Star confiuration (3.00 / 0) (#23)
by dinges on Wed Mar 5th, 2008 at 04:12:35 PM MST
Martin,
Assuming that in all three cases the same amount of power would be lost in the wiring:
In the case of 3 lines (AC) coming down the tower vs. 2 (DC) coming the tower: yes, with 3 wires (more or less in parallel) you could use thinner wires and still end up with the same line loss. The new wires could be 20% or 25% less in diameter. I'm not sure which of the two figures is correct, still pondering that myself and won't get into detail here, as I'm already accused of thread hijacking. The difference is mainly academic anyway.
In the case of 6 lines (with star/delta at ground level)  vs. 3 lines coming down the tower, since the wires are now in series (2 sets of 3 wires), each of the 6 wires would actually have to be thicker than the wires in the 3-line-AC system. Since total length of the wires is now doubled, area of each wire should be double too (or in other words, diameter should be (sqrt(2)) = 1.41 as large.
At least, if I understand things correctly. If not I'll be no doubt corrected by others :)
Peter.
Re: Star confiuration (3.00 / 0) (#24)
by dinges on Wed Mar 5th, 2008 at 04:27:34 PM MST
Better explanation:
http://www.windstuffnow.com/main/3_phase_basics.htm
Peter.
Re: Star confiuration (3.00 / 0) (#21)
by finnsawyer on Wed Mar 5th, 2008 at 08:49:07 AM MST
It would be possible to place a regular three phase (a 12 magnet 9 coil) and my single phase design (12 magnets 18 coils) on the same rotor/stator set up.  The three phase would be inboard of the single phase, both having the same size magnets and coils, although the set for my design should be wired two in hand.  If I am right about the power relationships the three phase could be used for low winds with a switch over to the single phase at an appropriate point.  Both alternators would be providing power at the high end.  Mixing three phase and single phase outputs should not be a problem when charging batteries.
GeoM
Star confiuration | 25 comments (25 topical, 0 editorial)
