Solar heat's working! Thank you all! | 7 comments (7 topical, editorial)
Re: Solar heat's working! Thank you all! (3.00 / 0) (#4)
by huntedheads (huntedheadsathotmaildotcom) on Sun Mar 30th, 2008 at 05:09:06 PM MST
Normally it's more interesting to produce DHW (=domestic hot water I suppose) then space heating.
With the the surface you have you can probably make all of your hot water in summer and a part of it in winter.In other words you use 100% of the heat produced
I will use 100%. I will be heating the hot tub come summer they need to be about 103 degrees! so I do have a year round use for the heat. And the collector will go to the roof come summer also oriented @ my lattitude + 23 degrees? I think? It's printed upstairs in a file somewhere, I'll find it when it's time. I will be setting it directly into the solar noon winter sun.
As for the water tank there is only my wife & I so some preheating is all I'm after if it's free I'll take it.
Solar heat's working! Thank you all! | 7 comments (7 topical, 0 editorial)
