Goldmine of parts. | 14 comments (14 topical, editorial)
Re: Goldmine of parts. (3.00 / 0) (#7)
by Sly on Sun Mar 30th, 2008 at 10:01:39 AM MST
Hi Zapmk,
The picture showing EPE FPS-1000 and the key pad is an Uninteruptible Power Supply. We have just de-commisionned one at work. The back up side of ours consisted of 4 x 12VDC batteries in series for 48VDC. If it still works it would be a very good start to a RE system. i.e. it can be used as an inverter when powered by your 48VDC battery bank. The added bonus is you could top up your batteries with the built in charger if you had too assuming your are not running a huge battery bank. If I remember correctly the AC wave out of it was decent and the unit was rated at 4KVA. The display is also nice showing volts/amps/freq etc... in and out and it could be mounted remotely. (Check if yours can be removed, ours was just plugged in)
I will check tomorrow to see if there might still be a manual floating around if you need it.
sly
Re: Goldmine of parts. (3.00 / 0) (#8)
by zapmk (user name at zap-comp dot com) on Sun Mar 30th, 2008 at 10:21:00 AM MST
Tried Googling for a manual, no such luck.
I think I'll hold off from scraping it out for a while.
The battery banks were wired for 120 volt output.
Found a tag:
AC output
Volts: 120/208/240
Amps: 149/84/73
DC input:
Volts: 120
Amps: 151
  1. KVA at .83PF
  2. Phase 60HZ
Re: Goldmine of parts. (3.00 / 0) (#10)
by zapmk (user name at zap-comp dot com) on Mon Mar 31st, 2008 at 03:24:55 AM MST
Man, that would be great if I could get a hold of a manual.
Goldmine of parts. | 14 comments (14 topical, 0 editorial)
