If that thing is as big as it looks then you will need a very large flow of water. As long as you can supply that then it should work fine.
It will not be a Kaplan ( variable pitch blades) so you will need to work round its speed and load characteristics.
You need to be up in the 100 gallons/minute region for a small reaction turbine.
