Bluefields Nicaragua 'report' | 45 comments (45 topical, editorial)
Re: Bluefields Nicaragua 'report' (3.00 / 0) (#9)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Fri Mar 7th, 2008 at 07:52:10 AM MST
A really nice report from the field.
My feeling is that somehow the design is
a bit too delicate. Quite small problems
with constructing will put the machine to fail
completely.
Maybe the problem is mainly with the quality
of the work needed.
Sometimes I'm wondering if better bearings
like ball bearings with the furling tail would
make the furling system more reliable.
Another thing I've been thinking about
would be to use more blades and less speed...
but then you would have more difficulties with
building even slower speed generator...
Re: Bluefields Nicaragua 'report' (3.00 / 0) (#10)
by DanB (danb@*no spam*otherpower.com) on Fri Mar 7th, 2008 at 08:31:50 AM MST
I think really the problem is - like you said, the machine has very little safety factor in the alternator.  The origional design calls for a 24V stator that comes in around .6 ohm.  So at rated  output (1000W) the stator needs to dissipate close to 1000W and it's not up to the task.  By using larger magnets we cut that figure in half which should add quite a lot of safety factor I think.
Re: Bluefields Nicaragua 'report' (3.00 / 0) (#11)
by Flux on Fri Mar 7th, 2008 at 09:22:15 AM MST
Hannu I don't think it makes a lot of difference with mounting the tail on ball races. It doesn't do any harm and it may have a much longer life but it makes little difference to the furling.
Using ball races for the main yaw may help slightly but it does also encourage it to yaw about more. Again I am not sure it is an advantage  as far as control is concerned.
There seems to be no way to make furling a precise process, variations of 2:1 in the current in the region of furling seems to be unavoidable and the thing ultimately has to survive the highest of these currents. The relative heating in the high peaks does depend very much on the site. Turbulent sites may have little energy in these peaks but on a good clean site in a good wind area the high peaks may continue for many seconds or minutes. Usually as the wind becomes more severe most machines drop power beyond furling, these tend to survive but those which hold peak current or worse those where current continues to rise are likely to cook.
One big problem is that variations in construction does seriously affect the prop speed, power curve and the furling characteristics.
The axial machine is very forgiving in that it will work with vast differences in construction whereas a badly wound radial just won't work, the thing will not go together if the coils won't go in the gap.
Other factors such as line resistance also also have similar effects and when several factors come together you may get a machine that performs badly but never burns out at one end of the range and at the other you may get wonderful performance with short life.
If you can't have quality control then the only cure is to drastically over build it, expensive in the short term but with little effect in the long term running cost.
I think under these circumstances with limited facilities and skilled labour adding bearings to tails any yaw would drastically increase the risk of failure rather than help.
Re: Bluefields Nicaragua 'report' (3.00 / 0) (#15)
by jmk on Fri Mar 7th, 2008 at 08:10:35 PM MST
 I can understand everthing Flux said. That's a once in a while thing for me. I think overbuiding and weather proofing is a must for them, and everyone with the corosive climates has alot more to deal with. Here is where the standers should get set.
jmk
Re: Bluefields Nicaragua 'report' (3.00 / 0) (#40)
by blueEnergy group (contact@blueenergygroup.org) on Wed Mar 26th, 2008 at 03:22:56 PM MST
(User Info) http://www.blueenergygroup.org
Our philosophy is to overbuild and keep working at improving capacity levels so the quality level of the work continues to rise.  In time we can re-evaluate whether we can scale back our "overbuilding" if our quality reaches a respectable point.
Cheers,
Mathias
blueEnergy
Re: Bluefields Nicaragua 'report' (3.00 / 0) (#39)
by blueEnergy group (contact@blueenergygroup.org) on Wed Mar 26th, 2008 at 03:21:03 PM MST
I think it is a robust machine design, given that the builders understand that some parts do require some precision.  Any dynamic machine will have this requirement.  As we get better at understanding which parts require precision and which parts don't, our machines will get more and more robust while still staying "realistic" given our working conditions.
Cheers,
Mathias
blueEnergy
Bluefields Nicaragua 'report' | 45 comments (45 topical, 0 editorial)
