New Motor Conversion | 14 comments (14 topical, editorial)
Re: New Motor Conversion (3.00 / 0) (#12)
by WXYZCIENCE on Sat Mar 8th, 2008 at 10:22:24 AM MST
SparWeb, I started on a similar motor convert. Link
http://www.fieldlines.com/story/2006/5/11/2116/17183
Zubbly gave me lots of info on it. Haven't done much on it. I will be very interested in how your's fairs.
Joseph.
Re: New Motor Conversion (3.00 / 0) (#13)
by SparWeb (sparweb at ANTISPAM_hotmail_com) on Sun Mar 9th, 2008 at 10:11:18 PM MST
Hi Joseph,
That posting goes back a couple years so it seems I got ahead of you somehow.  I remember that picture, so I must have found it before, in preparing to convert my first one.
I just had a brain-wave, while looking at another 3-phase motor I had and realized that I could take out its rotor, turn it down just a bit, and it would fit into this Baldor.  No risk of making things fall apart turning the rotor down too far.  Also a bit of trimming on the bearing shoulder to get it to the right length and ready for magnets!
I will have some more concrete details of what I accomplish later.  I'm doing this in small steps to check the results as I go.
Steven Fahey
Re: New Motor Conversion (3.00 / 0) (#14)
by oztules (oztules__at__bigpond.com) on Mon Mar 10th, 2008 at 03:26:43 AM MST
I notice that Zubbly addressed the magnet span for the concentric wound coils  and gives a diagram of it here :
http://www.anotherpower.com/gallery/zubbly/magnet_set_square_between_coil_legs
should you wish to use the original winding.
So the magnet width = inside dimensions of the smallest coils in the pole...... seven teeth wide.
.........oztules
New Motor Conversion | 14 comments (14 topical, 0 editorial)
