New Motor Conversion | 14 comments (14 topical, editorial)
Re: New Motor Conversion (3.00 / 0) (#4)
by dinges on Fri Mar 7th, 2008 at 07:49:40 AM MST
Hello Steven,
Nice motor and will follow your adventures with interest. Reading your, Flux and Oztules' responses has taught me a new thing or two again :)
I'm still looking for an (affordable) copy of Rosenberg myself. Parts of it can be read online and they certainly seem very interesting.
All the motors I've taken apart so far had only one coil leg per slot, so I suppose that method is really more common over here (Europe). In fact, until your post, I didn't know any better than that this was 'normal'. Another thing that continues to surprize me (and makes me jealous) is the fact that North-American motors tend to have a larger diameter-to-length ratio; the rotors are shorter but stubber. This should make for a better slow-running multipole genny. If you have a look at my 4-pole 3 hp conversion, you'll see that the rotor is much more slender: http://www.anotherpower.com/gallery/3HP-induction-conversion/motor_rotor_frontside
Was a bit surprised by Flux's remark that flux density of the 500 W conversion was low. It's nearly 1 T in the airgap above the magnets, whereas I understand that axial fluxes operate more in the 0.7 T range. (http://www.anotherpower.com/gallery/album69/blue_boy_FEMM_detail_average_flux_over_one_active_tooth)
But I must admit, I could have made airgap smaller, just that I have limited faith in my machining/building capabilities :) I don't recall having done a definitive FEMM simulation of the 10 hp conversion; that's another thing on the 'to-do' list for this weekend then...
You haven't explicitly stated so in your story but I understand you will use the stock winding and not rewind ? I forgot, but do you use 24 or 48 V system voltage ?
Peter.
PS: sent you an e-mail.
Re: New Motor Conversion (3.00 / 0) (#6)
by SparWeb (sparweb at ANTISPAM_hotmail_com) on Fri Mar 7th, 2008 at 08:44:46 AM MST
Actually, the total flux (webers) in your model is lower than what I get, by a factor of about 200.  That's what's got my attention.
I will need 24V.  Considering Flux and Oz's comments, I don't think I will have much success with the existing wave winding they describe.
That's okay, I was saving up for the big surprise with all the wire cut out!
Steven Fahey
Re: New Motor Conversion (3.00 / 0) (#7)
by dinges on Fri Mar 7th, 2008 at 08:51:04 AM MST
Strange about the total flux (Weber). Only thing that comes to mind is perhaps the units have been set incorrectly (mm vs. inch). Have just checked my FEMM model again but it's all in mm, as far as I can tell (planar, mm, depth of 1)
Peter.
New Motor Conversion | 14 comments (14 topical, 0 editorial)
