hands on work | 6 comments (6 topical, editorial)
Re: hands on work (3.00 / 0) (#5)
by blueyonder (windwoodgood at yahoo dot co dot uk) on Fri Apr 11th, 2008 at 06:59:40 PM MST
 thank you ghurd.
   i can carry on now with that rectifier thing out the way.
  you sure have a way of explaining  things.  thanks again john.
Re: hands on work (3.00 / 0) (#6)
by ghurd on Sat Apr 12th, 2008 at 07:31:39 AM MST
One last thing because you will think of it later.
Jerry Rigged lost 0.7V (or inches) off each end too.  But it doesn't matter the way I explained it with a 2x4.
The 2x4 is the same length if one end has 1.4" cut off, or both ends have 0.7" cut off.  The 2x4 is still the same length.
Glad it helped.
hands on work | 6 comments (6 topical, 0 editorial)
