Flow diagramm for combined water and space heating | 19 comments (19 topical, editorial)
Re: Flow diagramm for combined water and space hea (3.00 / 0) (#18)
by GaryGary (gary@BuildItSolar.com) on Wed May 7th, 2008 at 07:16:12 PM MST
(User Info) http://www.BuildItSolar.com
Oops!
This paragraph:
Check valve (2) prevents the solar pump from pushing water through the boiler in the wrong direction when in boiler mode.  The check built into pump (3) prevents the boiler from pushing water back through pump (3) and into the solar tank in the wrong direction when in solar mode.
Should read like this:
Check valve (2) prevents the solar pump from pushing water through the boiler in the wrong direction when in SOLAR mode.  The check built into pump (3) prevents the boiler from pushing water back through pump (3) and into the solar tank in the wrong direction when in BOILER mode.
Gary
Re: Flow diagramm for combined water and space hea (3.00 / 0) (#19)
by mbeland on Fri May 9th, 2008 at 11:15:10 AM MST
I think I get it. It could be a nice way to do without valves. GREAT!
Martin
Eau, soleil, le vent
Flow diagramm for combined water and space heating | 19 comments (19 topical, 0 editorial)
