Meanwhile any flaws in the fittings will cause a leak of the outer circuit water to the surrounding area, rather than between the two circuits.[ Parent ]
OK. Then solder a coil of copper tubing to a hunk of copper pipe, wrap it in insulation, and you're all set. Hydronic water through the coil top-down, convection loop between bottom and top of water heater through the inner (fat) straight pipe.[ Parent ]
