Vanner inverter damage | 11 comments (11 topical, editorial)
Re: Vanner inverter damage (3.00 / 0) (#6)
by commanda (alwynne at unwired dot com dot au) on Thu Apr 10th, 2008 at 03:34:57 PM MST
once clean and dry, i would assume i should coat them with something to protect
the boards and to aid in keeping further corrosion in check.
spray laquer, or is there a specific spray on finish to coat the boards?
It's called "Conformal Coating". The proper top-notch stuff we use for IS (intrinsically safe) mining gas monitoring equipment is not cheap. Most larger electronics suppliers will have some sort of aerosol lacquer (ask for Circuit Board Lacquer) for a reasonable price.
Re: Vanner inverter damage (3.00 / 0) (#8)
by bob g on Thu Apr 10th, 2008 at 08:37:31 PM MST
Thanks one and all
Amanda: thanks for the tip, we have a good electronics supply house here
i will check with them for the laquer
bob g
Vanner inverter damage | 11 comments (11 topical, 0 editorial)
