Saft NiCad Batteries | 18 comments (18 topical, editorial)
Re: Saft NiCad Batteries (3.00 / 0) (#14)
by joestue on Wed Apr 16th, 2008 at 12:09:15 AM MST
The Devil is in the details man!
You should never charge a sub C or D battery that hard because you can't add water.
Correct me if i'm wrong, most of the heat is from the recombination of the O2 and H2 during the charge, since the amount of reconbination is the same whether you charge it fast or slow, (within reason, the increased voltage due to cell resistance will increase gasification), the small chargers just assume that if you keep the temperature down, then the internal cell pressure can't be high enough to vent the cell. With vented cell types, there is an order of magnitude less recombination.
Also, the battery should cool upon charging, until it hits end of charge and the oxygen is consumed in the catalyst.
This is not necessarily the case for all batteries, the internal resistance varies considerably between manufacturers, for instance, some Nicds can discharge 50C, others are rated only 10C or less.
http://www.mpoweruk.com/nicad.htm
www.battcon.com/PapersFinal2005/MeisnerPaper2005.pdf
BTW Nimh chemistry is 66% chemically efficient on charge, and Nicd is ~55% on a 16 hour charge, and ~80% on a fast, ~2 hour charge. Both of which lead acid can beat.
Re: Saft NiCad Batteries (3.00 / 0) (#15)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Mon Apr 21st, 2008 at 11:45:23 AM MST
Joe;
 I like your numbers. The C/10 or C/20 would give a good long term charge for what he's wanting to do.
Lead Acid batts are good. My main reason for sticking with NiCds are that they can be drained down to having only 20% of their total charge left and be able to recover without a noticeable damage. In fact , they work better when used in this fashion.
When building or designing for NiCds the best way would be to use the negative slope method. NiMh have this slope too, but not as easy to detect.
Re: Saft NiCad Batteries (3.00 / 0) (#16)
by joestue on Mon Apr 21st, 2008 at 02:41:20 PM MST
I forgot about the 80% discharge part, thanks for catching that.
If you only discharge the first 40%, I bet you could get the efficiency up.
This doesn't apply to NIMH though, speaking of which why do they put these in hybrids?
they should use NiCds.
Re: Saft NiCad Batteries (3.00 / 0) (#17)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Tue Apr 22nd, 2008 at 03:26:47 PM MST
joestue
The main reason for them using the NiMh is the chemistry. They are way less dangerous. Cadnimum is a very bad thing, and MUST always be handled like the poison it is. Worse than lead paint!!
NiMh also loose their standing charge slower than NiCds do.
But possibly the more important reason is that they only last about 500 cycles before they start wearing out :-)
Lithimum is coming along just fine, once those have been around a bunch more years, they'll be better in the long run.
Price is what keeps them out of my reach.
Saft NiCad Batteries | 18 comments (18 topical, 0 editorial)
