Rotors spin each other. | 4 comments (4 topical, editorial)
Re: Rotors spin each other. (3.00 / 0) (#1)
by fcfcfc on Fri Apr 11th, 2008 at 04:25:26 AM MST
Hi: I don't know if I would necessarily draw that conclusion for a whole bunch of reasons. I don't know where exactly you used your non Ferris metals, but generally the uses of such will be realized as negative if they are stationary in relation to the magnetic fields allowing the generation of eddie currents. As part of the rotors it will just reduce field strength depending on where they are used.
Re: Rotors spin each other. (3.00 / 0) (#3)
by richhagen (richhagen (a t) Juno.com) on Fri Apr 11th, 2008 at 05:31:30 PM MST
Jerry posted a couple of photos of the buildup of these in a post just prior to this one here:  http://www.fieldlines.com/story/2008/4/11/5436/80877
Since the aluminum is spinning with the magnets there would be no flux change in them from the magnets.  Magnetic fields generated by the current in the coils in a real alternator might have some effect, but they are on the ends of the magnets.  I suspect that the screws might affect the pattern of the magnetic fields a bit, but I am not sure exactly how based upon the positions.
I would note that I can wire a couple of stepper motors together and the second will spin when the first one is spun, but they are not that efficient of generators.  Still, Jerry's rotors there look pretty good to me as 4 pole rotors.  I like Warrior's use of the steel outer shoe with multiple smaller magnets too.  Rich
Rotors spin each other. | 4 comments (4 topical, 0 editorial)
