Disaster with wind turbine | 34 comments (34 topical, 0 editorial)
Re: Disaster with wind turbine (3.00 / 0) (#20)
by TimV on Sun Apr 13th, 2008 at 08:18:29 PM MST
You can bore your existing hub(if it is large enough) to accept a stock weld in hub that will take a taper lock bushing.
Or a shop could taper bore your hub  and drill it and thread it so it would take a Taper lock bushing to.
Re: Disaster with wind turbine (3.00 / 0) (#25)
by imsmooth on Mon Apr 14th, 2008 at 02:41:14 PM MST
(User Info) http://www.mindchallenger.com
I think this is what I am going to do.  The shaft is 25mm.  I can bore the rotor hub to take the shaft and key.  I can bore the shaft in front down to 0.875 to take a standard 0.875in bushing taper lock from grainger.com
Will 0.875 steel shaft be ok for an 8.5' rotor?
Jonathan
Re: Disaster with wind turbine (3.00 / 0) (#34)
by domwild (domwild at hotmail dot com) on Fri Apr 18th, 2008 at 01:35:19 AM MST
Jonathan,
As one inch is 25.404 mm you should have no problem finding a taper lock to go with your 25.00 mm shaft.
Regards,
dom We only ever use the best fencing wire for our repairs!
