Disaster with wind turbine | 34 comments (34 topical, editorial)
Re: Disaster with wind turbine (3.00 / 0) (#4)
by imsmooth on Sat Apr 12th, 2008 at 09:10:15 PM MST
(User Info) http://www.mindchallenger.com
This is pertinent for me at this time.  I have a F&P shaft with a 25mm spline.  I just ordered a hub from TLGWindpower for an 8.5' rotor.  The hub has a 17mm hole.  I was going to go to a machine shop, have the hole enlarged, smooth and key the spline and use a key lock.  Now you are saying that this is not good.  Is it that the lock screws fail under the constant stress?
Other than welding, you mentioned a tapered locked hub?  How is this held in place?  If the shaft tapers can't the hub come off the front?  Do you have a picture or diagram and I will bring this to the shop and have this done instead?
Jonathan
Disaster with wind turbine | 34 comments (34 topical, 0 editorial)
