Periodic Maintenace is a GOOD THING | 7 comments (7 topical, editorial)
Re: Periodic Maintenace is a GOOD THING (3.00 / 0) (#6)
by Capt Slog (Capt.Slog(at this)gmail.com) on Wed Apr 16th, 2008 at 02:55:39 AM MST
I check mine out regularly, mainly because I'm terrified of it going wrong.  Usually it's enough to stand under it and look up through the rotors and see that there is still clearance as I left it.
A pair of binoculars helps for a close up inspection, such as are all the bolts where they should be?
But every now and then it comes down and gets a thorough check, grease where it needs it and a quick going over with a spanner to make sure all is tight.
Periodic Maintenace is a GOOD THING | 7 comments (7 topical, 0 editorial)
