3 HP motor conversion | 21 comments (21 topical, editorial)
Re: 3 HP motor conversion (3.00 / 0) (#17)
by briskwinds on Sun Apr 20th, 2008 at 05:00:00 AM MST
Thanks Vawtman,
I understand. 23 mm pole width near the stator teeth (3 teeths). My two magnets will side by side will cover more than that. A single 23 mm magnet will be of same width on the rotor and near the stator teeth. So 12 Pole is out of question for my magnet size.
But what about 6 pole. How many teeths per coil so that I can find what the length of the pole and see if my magnets fits it perfectly.
Secondly is it true that wire size doesn't matter for test winding. We only need to know the voltage at cut-in speed from the test winding.
Re: 3 HP motor conversion (3.00 / 0) (#18)
by vawtman (vawtman(at)charter(dot)net) on Sun Apr 20th, 2008 at 05:53:00 AM MST
 For 6pl you would have 4 open slots.~46mm.2 coils per group.Has flux stated
I could upload a pic of a partial 4pl winding later if you want.It has 6 open slots
 your motor man should understand this i would think.
 Mark
3 HP motor conversion | 21 comments (21 topical, 0 editorial)
