Where Can I Obtain These Battery Connectors? | 14 comments (14 topical, editorial)
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#4)
by nick1234 on Fri Apr 18th, 2008 at 07:38:21 PM MST
if you do not find the connector and in a hurry you could make some with some thick wall brass tube drill to size cut a X at the end to a depth greater than the length of the post squish in for tight fit put a peace rubber hose  for insulation  connect wire at other end
enjoy
nick1234
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#5)
by Jerry on Fri Apr 18th, 2008 at 10:41:12 PM MST
Hi Slingshot.
I drilled and taped mine for 1/4-20 threds. I used a brass washer between the copper bus barr.
The bar is held to the battery post with 1/2" long 1/4- 20 brass bolts. This has been working great now for several years.
This is a 48 volt system.
Airheads Page
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#7)
by Spaz (jraba@mass.rr.com) on Sat Apr 19th, 2008 at 08:57:33 PM MST
(User Info) http://crosscountrycommercialflooring.com
i think i saw a connector for that on EVparts.com I don't remember the price
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#8)
by mbeland on Mon Apr 21st, 2008 at 08:34:23 AM MST
Pretty neat set up! Do I understand well, they are sealed so it means you don't have to water them up so that's why you can pile them up that way?
Martin
Eau, soleil, le vent
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#9)
by Slingshot on Mon Apr 21st, 2008 at 09:28:22 AM MST
Jerry,
I assume this means that the terminal posts are solid, not hollow?
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#13)
by Jerry on Tue Apr 22nd, 2008 at 09:14:05 PM MST
Hi Slingshot.
Yep they are solid not hollow.
Airheads Page
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#10)
by Slingshot on Mon Apr 21st, 2008 at 09:30:12 AM MST
Thanks, I was thinking about that also, because the terminals reminded me of the connection posts on my crackerbox welder.
Where Can I Obtain These Battery Connectors? | 14 comments (14 topical, 0 editorial)
