has any one installed a reverse osmosis system | 22 comments (22 topical, 0 editorial)
Re: has any one installed a reverse osmosis system (3.00 / 0) (#16)
by getterdone on Sat Apr 19th, 2008 at 05:25:06 PM MST
activated [baked].
could i use bricketts as used in charcoal grilling?
If I were smart I'd be dangerous
Re: has any one installed a reverse osmosis system (3.00 / 0) (#18)
by spinningmagnets (velmis1450bc(at)aol(dot)com) on Sat Apr 19th, 2008 at 09:56:39 PM MST
I dont know about charcoal bricketts, might be possible...
The activated charcoal we used came in fine thread cloth bags. When water sampling showed the water output chemicals were rising (in parts-per-million/PPM) we would stop and swap out the bags.
I am using the Brita charcoal-filter water pitcher to clean the city water a little for my coffee in the morning. I don't know how much it helps, but it does taste better.
Re: has any one installed a reverse osmosis system (3.00 / 0) (#22)
by tanner0441 on Wed Jul 23rd, 2008 at 03:34:24 PM MST
Hi
 I live in the UK (North Wales)the drinking water smells like it came from a swimming pool so much chlorine, so I fitted two small filters under the sink, about 2 inches dia and 9 inches long, the first one is a micro porus ceramic filter removes particles and all the lepto type spores and cysts, the second one is a carbon block filter.  Carbon block offeres a greater surface area than particles. the complete set up including a small tap was around £50 the water is a good as any bottled water and therre is no chlorine, chlorine has been linked to colon cancer so best avoided.
Brian..
Re: has any one installed a reverse osmosis system (3.00 / 0) (#19)
by elvin1949 (elvin1949@yahoo.com) on Mon Apr 21st, 2008 at 01:06:43 AM MST
getterdone
  Short answer NO   bbq bricketts have chemical
binders in them that would not be good for your health.
  Some where the federal gov. has guidelines and plans online for a cistern filter.seems like i remember it was a 3 stage filter.
 Pea gravel--sand--activated charcoal
It has been a long time,so i don't remember how i found it.
Elvin
