has any one installed a reverse osmosis system | 22 comments (22 topical, 0 editorial)
Re: has any one installed a reverse osmosis system (3.00 / 0) (#5)
by scottsAI (user name at eml dot cc) on Fri Apr 18th, 2008 at 10:52:42 PM MST
Getterdone,
Saved the best for last:
http://www.builditsolar.com/Projects/Water/Water.htm
Otherpower is about wind, not going to get much response on other subjects.
I have read everything linked to above. I would say I am book smart on rainwater.
Cistern when a kid, collect rain to water my batteries.
Not found a water diversion device I like (or willing to pay for), designed my own, which I do not like yet. Love to see anything you can come up with...
I live in Michigan, with a 2000sqft home a 2500gal tank for family of 4.
Sister in NM, would need 5000gal tank, same yearly rain fall. NM has no rain for months.
Made a spread sheet to calculate tank size based on monthly rain fall. I used the low numbers to calculate, not willing to run out of water!
Found plastic tanks for 2500 gal cost $1000 or so with shipping.
Ebay item 250237686170
Then came across the idea of digging a hole or a wood tank.
Line it with EPDM pond liner (60mil) about $1sqft, much less $ then the tank.
May be a problem for code and flooding considerations. So have top above ground.
Need a cover. How about a deck? Same idea works for solar heated tank.
Estimated it would cost $2k to use rain to replace a $8k well. Looks like a good deal, gave me the $ needed to do solar heating! Got laid off, building is on hold.
I can drive a shallow well for few hundred $, use for watering lawn.
Have fun,
Scott.
