I believe lglagasse misunderstood the earlier posts.
The 4500W element should hold up fine, but it would be nearly pointless.
Watt's Law 4500W/120V= 37.5 AMPS.
Best bet is the voltage is 240V instead of 120V.
So 4500W/240V= 18.75A.
And Ohm's Law 240V/18.75A= 12.8 ohms.
A 12V system dumping excess power at 14V, into a 12.8 ohm resistance is less than 1.1A, or 15W. 15W is about half of a car tail light bulb.
A 48V system dumping excess power at 56V, into a 12.8 ohm resistance is less than 4.4A, or 245W.
A 4500W heating element using 245W (or 5% of rated watts) is likely to last a LONG time.
What TomW said...
"Watts Ohms Amps and Volts all work together and it is a very simple set of formulas that help you figure this stuff out"
