Fisrt diary post: house description and tentative flow diagram | 24 comments (24 topical, editorial)
Re: house description and tentative flow diagram (3.00 / 0) (#22)
by scottsAI (user name at eml dot cc) on Fri Apr 25th, 2008 at 12:06:13 PM MST
Martin,
70's American Motors (AMC) imported a Renault vehicle they called "le car" for little car.
I remember hearing the French gov did not like this name, if I got this right "The French do not like the butchering of the language like the Americans do"... What can I say I thought it was funny.
Taller tank looks like it will work for you. The weight of the tank is huge, make sure the slab its on can handle the weight without breaking.
I mentioned earlier do you have a porch without a basement under it?
Great place for a large tank. Digging the hole by hand is not too bad. I have done the foundations for a home only took a couple days.
Solar collectors sized by the heat needed by the pool, everything else will be taken care of.
Have fun,
Scott.
Re: house description and tentative flow diagram (3.00 / 0) (#23)
by mbeland on Fri Apr 25th, 2008 at 01:34:39 PM MST
Now I remember the Le car story. I think it was the Renault 5. A very cheap, valuable but very noisy car. Reticence from the French gov won't stop me from playing with words. It's too much fun, especially with two languages (read in French 2 tongues)...
About the slab. Does anyone know how heavy a 4 inch thick slab reinforced with wire mesh can withstand?
I do have a porch but it is only 4 x 8 ft. I doubt it is worth the trouble of digging and making a hole in the basement wall, more difficulty to insulate the tank
If I split the tanks in 2 (within my technical room), I wonder how I could place the inlet and outlet vs heat exchanger coil... Connection between the two tank I guess should be at the bottom.
Martin
Eau, soleil, le vent
Re: house description and tentative flow diagram (3.00 / 0) (#24)
by zeusmorg on Fri Apr 25th, 2008 at 04:11:07 PM MST
 As far as the PSI of your concrete, it depends on several factors, grade of concrete used, and how well the ground underneath was compacted before pouring. The wire mesh reinforcement really makes no difference, that just retains cracks is about all.
 If the slab was properly done, you should have no worries putting a water tank on top. Tap on the concrete to see if you can detect any hollow areas, if any are present then you have some worries.
 Location of a pipe for balancing the water level isn't critical. Water seeks it's own level. Personally, I'd build one large tank with an insulation barrier between them. You create less exterior surface area that way and a lower need for heavy exterior insulation. The top is probably the most critical for insulation, as heat rises. That would save you from any additional heat load in your house in the summer.
 Heat exchangers should be placed near the top for heating applications, (pool, DHW) and at the bottom for solar panels. In other words you want to utilize the hottest part for your heating applications and heat the coolest part. Of course if you go drainback, that is inconsequential, pickup at the bottom, and return at the top.
Fisrt diary post: house description and tentative flow diagram | 24 comments (24 topical, 0 editorial)
