low RPM rumble | 14 comments (14 topical, editorial)
Re: low RPM rumble (3.00 / 0) (#10)
by TheCasualTraveler (a.miklos@yahoo.com) on Wed Apr 23rd, 2008 at 06:59:07 AM MST
OK, thanks people.
     Flux mentioned if the magnet disc was potted,   well, it's not. Magnets are epoxied and the disc painted. Only my test machine so it's fine but now I know for the new machine I'm working on. The machine I'm building now has four bolts in addition to the center bolt. I need this to make sure that with a second magnet disc the two stay aligned. With only a blank steel disc on my test machine there was no need to have more than the center bolt as the discs did not need to be aligned at a certain point.
     So for my  machine in progress I will have a thicker, stronger stator, potted magnet discs, four bolts between discs and I think I will also try a large plastic bushing on the center shaft between discs for dampening any noise. I won't expect silence but I will try to eliminate unnecessary noise.
     On a side note I have finished carving the wooden blades for this machine. They came out great. I used Ed's plan, here
http://www.windstuffnow.com/Blade-layout.pdf
     About the time that my arm was getting tired from patting myself on the back I had the humbling realization that the instructions were so good anyone following them would have the same results I had. I asked Ed about the TSR of these, (I scaled them down to 36" for 6 foot from his 39") He said they will run about 6 maybe a little higher since I made them shorter. My greatest motivation was the fear that responses from Flux would have a line something like, "I forget what your doing, are you still playing with PVC blades?" Here's a couple pictures.
Mr Tom, sorry if I screwed up on picture size but I really tried to get them legal.
Andy
low RPM rumble | 14 comments (14 topical, 0 editorial)
