low RPM rumble | 14 comments (14 topical, editorial)
Re: low RPM rumble (3.00 / 0) (#4)
by wpowokal on Tue Apr 22nd, 2008 at 06:26:40 PM MST
What Woof said, and my 5 phase duel rotor still has vibration, thankfully I'm deaf enough not to hear it unless I go out to the tower.
It is a fact of AC life, now you are aware of it try listening to an AC motor or a small (or any size actually) transformer etc. Place a screw driver on the motor with the plastic end on your ear Hmmmmmmm.
allan down under
Re: low RPM rumble (3.00 / 0) (#7)
by Flux on Wed Apr 23rd, 2008 at 02:01:30 AM MST
All electrical machines have the potential to make a noise. Every coil is going to have a pulsating force acting on it and there will be forces reflected on the magnets. Even dc machines ( dynamos) make a noise.
With a single phase winding the torque pulsation is additive from all coils . Any polyphase machine will balance most of the total torque variation and be much smoother. Beyond 3 phase there will be virtually no improvement in total torque variation ( even 2 phase is almost there).
What sometimes happens is that a mechanical resonance picks up and amplifies a certain frequency and that is almost certainly what you have in your case. Finding the resonance is a more difficult problem. Usually the noise can be lived with, I have always got noise from my machines at some speed. If you had a fast commercial machine with noisy blades you would be unlikely to even hear the alternator noise.
If you have potted the magnets then my immediate suspicion would be bell mode resonance on the return disc with no magnets although I have never experienced significant noise with this type of construction.Casting a layer of epoxy or vinyl ester on the back of the blank disc may be enough to damp it ( it would at least eliminate that as a possible source). Stator mountings may not be rigid enough and if you beef them up and shift the noise to another speed then you have a clue that that is causing a problem.
I suspect you have a strong resonance if you are exciting it near cut in where the magnetic forces are small. You may even be able to excite it mechanically by tapping things with a small hammer and looking for the same note. Even bearing tightness may be a factor is you have taper rollers.
No point in doing any electrical redesign with different number of phases, you may accidentally get an improvement but the potential to excite resonance will still be there and you could hit things even worse at another speed.
If you have such a thing try a large inductance (choke) in the dc line, it works wonders with single phase, I have never seen any advantage for polyphase but lengthening the conduction period may reduce the exciting forces. Unfortunately a decent very low resistance choke will cost the earth so if you don't have one dismiss this option.
Re: low RPM rumble (3.00 / 0) (#9)
by Flux on Wed Apr 23rd, 2008 at 03:32:28 AM MST
"Perhaps it is that my steel discs are only bolted on at one point through the center instead of 4 or five bolts like on a brake disc machine."
Didn't spot that bit before. That is likely to be very relevant , you will have very little damping on the plain disc and it could be excited by small vibrations at a resonance.
Re: low RPM rumble (3.00 / 0) (#11)
by TheCasualTraveler (a.miklos@yahoo.com) on Wed Apr 23rd, 2008 at 04:30:25 PM MST
Flux wrote,
""If you have such a thing try a large inductance (choke) in the dc line, it works wonders with single phase, I have never seen any advantage for polyphase but lengthening the conduction period may reduce the exciting forces. Unfortunately a decent very low resistance choke will cost the earth so if you don't have one dismiss this option.""
     My electronics knowledge is just enough to enable me to ask silly questions, but here goes. I have an old blown inverter that contains a nice heavy transformer. Is it at all conceivable to use half the transformer as an inductor?
My apology in advance, I am
Andy
Re: low RPM rumble (3.00 / 0) (#12)
by joestue on Wed Apr 23rd, 2008 at 05:56:56 PM MST
Yes and no. You can keep the coil and core, but you are going to have to relaminate the core with all the E's on one side, and a piece of plastic about 1/16th inch thick separating all the I's, forming an air gap. Otherwise, the core will saturate, and have relatively no inductance.
low RPM rumble | 14 comments (14 topical, 0 editorial)
