Baldor 24V DCPM 1/4 HP Geared motor | 4 comments (4 topical, editorial)
Re: Baldor 24V DCPM 1/4 HP Geared motor (3.00 / 0) (#1)
by ghurd on Wed Apr 23rd, 2008 at 01:56:09 PM MST
Not very well.  The gears kill the idea.  It might work a little, but I would say don't waste the effort and money.
If the motor's RPM is low enough, then the motor might work, but usually geared motors are way too fast.
Re: Baldor 24V DCPM 1/4 HP Geared motor (3.00 / 0) (#2)
by farhan on Thu Apr 24th, 2008 at 03:44:04 AM MST
Thank you for your comment, the motors rpm after putting the gears are 178, so thats low, with just a turn from hand it makes 12v easily and lights a 12v bulb. The geared part can be removed as well but i'll have to check what rpm it needs then because after removing gears even if i twist with hands it makes very low volts.
Baldor 24V DCPM 1/4 HP Geared motor | 4 comments (4 topical, 0 editorial)
