My Humble, Yet Cheap Solar Set-Up | 9 comments (9 topical, editorial)
Re: My Humble, Yet Cheap Solar Set-Up (3.00 / 0) (#1)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Tue Apr 29th, 2008 at 07:06:44 AM MST
That's a great start and enough power to have some good fun with
at the bottom the first picture I see more solar panels, what's up with that ?
What voltage are you running at ?
a few observations . . .
The batteries look like they are hooked together with very small wire.
I don't see any fuses or breakers.
looks like enough ventilation in the box but I wouldn't keep the rest of the controllers and inverters in there with the batteries, the gasses can be corrosive.
W o o f -={(
Re: My Humble, Yet Cheap Solar Set-Up (3.00 / 0) (#3)
by mettleramiel on Tue Apr 29th, 2008 at 09:11:54 AM MST
One of those panels is for the little fan you see below the charge controller, the other one is for charging a small portable powerbox that I use to charge small devices.
The wires are 6ga and each battery has a fuse. You can see one of them, it's that black, cylinder with the yellow stripe.
Like the guy below observed, these are gel batteries so they don't gas, plus, I have that fan sucking air out and the front of the box is cut at the top to make a big vent gap.
My Humble, Yet Cheap Solar Set-Up | 9 comments (9 topical, 0 editorial)
