My Humble, Yet Cheap Solar Set-Up | 9 comments (9 topical, editorial)
Re: My Humble, Yet Cheap Solar Set-Up (3.00 / 0) (#3)
by mettleramiel on Tue Apr 29th, 2008 at 09:11:54 AM MST
One of those panels is for the little fan you see below the charge controller, the other one is for charging a small portable powerbox that I use to charge small devices.
The wires are 6ga and each battery has a fuse. You can see one of them, it's that black, cylinder with the yellow stripe.
Like the guy below observed, these are gel batteries so they don't gas, plus, I have that fan sucking air out and the front of the box is cut at the top to make a big vent gap.
My Humble, Yet Cheap Solar Set-Up | 9 comments (9 topical, 0 editorial)
