Hybrid Wincharger Update (photo) | 11 comments (11 topical, editorial)
Re: Hybrid Wincharger Update (photo) (3.00 / 0) (#8)
by Dave B on Thu May 1st, 2008 at 11:36:01 AM MST
I like to balance everything with it all together on the tower and know I can get it close, (no load of course) I do use the rear grease seal but remove the spring that tensions the rubber and also just slightly cut a bit of the lip of the seal to lessen the drag, I'm glad it's on there. On my previous I used low temp (snow mobile grease) which seemed to work well in sub zero temps. to help it start up a bit easier but at 18' I don't think I could have really known how much it helped. I have bronze bushings at the top of the yaw bearing and tail pivot that I hole saw cut from 1/2" plate to fit (ain't cheap) and are greased besides. After inspecting these from before I think they will last forever. Waiting on the wind,  Dave B.
Re: Hybrid Wincharger Update (photo) (3.00 / 0) (#9)
by jmk on Thu May 1st, 2008 at 11:22:31 PM MST
All I was trying to say was that after all you can do is done you can tell how well you did by looking at the tail and feeling the tower. I don't think that the dust cap thing  matters after ten foot. I greased mine booth ways and couldn't tell the difference. If there is it isn't worth worrying about, so you might just as well grease it. To tell you the truth the balance changes with the weather. You have experienced more than I with wind turbines anyway. I am just trying to give my two cents. You are well on your way.
jmk
Hybrid Wincharger Update (photo) | 11 comments (11 topical, 0 editorial)
