Put house in the shade for the summer | 12 comments (12 topical, editorial)
Re: Put house in the shade for the summer (3.00 / 0) (#2)
by etownlax on Thu Apr 3rd, 2008 at 03:07:38 PM MST
In the United Arab Emirates there is this Ski resort that is indoors. Outside temperatures can easily reach 100 F. Their best form of insulation is acutally air. It was on TV(think it was the Travel channel maybe Discovery) that they showed around the place. Then they showed how they kept it best insulated, and that was a gap of air between the inside and the outside of the resort. Air is a VERY good insulator. Air does not transport heat very well. However the way this works best is if that air doesn't get replaced by the hot air on the outside. Think of it this way. A cooler is a good insulator. If you put steak in it with ice, it should last a good while. Now if you Allow the Cooler to "Change"(like allowing the air to move bringing hot air in and removing cool air) By replacing it with a cooler that has been heated inside and out, it really totally defeats the purpose and makes the steak go bad quicker. Thats prety much what your attic is alreay for.
So sure the sun isn't helping but, if you were to "enclose" an additional part even beyond your attic and roof. That would help a whole lot more, But it would cost a GREAT deal. Also if you just used a reflective "paint"(if thats even legal) that would shield a good amount of sun too.
Just some thought to ponder. I figure more ideas the better, cause it couldn't hurt.
-Randy
Re: Put house in the shade for the summer (3.00 / 0) (#3)
by richhagen (richhagen (a t) Juno.com) on Thu Apr 3rd, 2008 at 04:42:53 PM MST
I believe that most common types of insulation actually work by trapping air spaces so there is little or no convection, then the trapped air conducts poorly and radiates poorly, so less heat is lost.  Rich
Re: Put house in the shade for the summer (3.00 / 0) (#4)
by valterra on Thu Apr 3rd, 2008 at 05:22:41 PM MST
So in the case of my house (regular split-level), I can use your ideas like this:
  • better insulation in the attic to seal in the living space of the house.  That living space would be like the cooler you mentioned.
  • an attic fan that would remove stale, hot air from the attic area, so the air adjacent to the "cooler" isn't  burining hot?
  • or are we saying that actually trapping the air in the attic would be better because it can't exchange?  that doesn't sound right for some reason.  I always thought attics were like ovens, trapping hot air.
Re: Put house in the shade for the summer (3.00 / 0) (#5)
by richhagen (richhagen (a t) Juno.com) on Thu Apr 3rd, 2008 at 05:38:01 PM MST
I would say that adding insulation between the attic space and the living space would be very worthwhile thing, especially in winter where escaping heat rises.
Ventilating the attic is a good thing because of the heat gained by the air in this space by the sun light baking the roof above.  If the temperature in the attic is higher than the ambient outdoor temperature then ventilating it would be beneficial.  Heat is transferred by convection, conduction or radiation.  Things that aid in heat transfer away from the living space, or minimize heat transfer into it will be good things in general.  Most convection, the movement of material is hot air moving upward, not down from the attic to the house unless pressure differences occur (why top opening freezers tend to be more efficient).  Conduction is a function of the cube of the temperature difference if I recall correctly, so minimizing this would be beneficial, which means that cooling a hot attic would be to some extent beneficial in this regard, and keeping surfaces cooler means that they will radiate less energy as well.
Having a light colored roof which reflects more of the light striking it would also help - or just build a shade of solar panels above it :-)  Rich
Put house in the shade for the summer | 12 comments (12 topical, 0 editorial)
