Put house in the shade for the summer | 12 comments (12 topical, editorial)
Re: Put house in the shade for the summer (3.00 / 0) (#4)
by valterra on Thu Apr 3rd, 2008 at 05:22:41 PM MST
So in the case of my house (regular split-level), I can use your ideas like this:
  • better insulation in the attic to seal in the living space of the house.  That living space would be like the cooler you mentioned.
  • an attic fan that would remove stale, hot air from the attic area, so the air adjacent to the "cooler" isn't  burining hot?
  • or are we saying that actually trapping the air in the attic would be better because it can't exchange?  that doesn't sound right for some reason.  I always thought attics were like ovens, trapping hot air.
Re: Put house in the shade for the summer (3.00 / 0) (#5)
by richhagen (richhagen (a t) Juno.com) on Thu Apr 3rd, 2008 at 05:38:01 PM MST
I would say that adding insulation between the attic space and the living space would be very worthwhile thing, especially in winter where escaping heat rises.
Ventilating the attic is a good thing because of the heat gained by the air in this space by the sun light baking the roof above.  If the temperature in the attic is higher than the ambient outdoor temperature then ventilating it would be beneficial.  Heat is transferred by convection, conduction or radiation.  Things that aid in heat transfer away from the living space, or minimize heat transfer into it will be good things in general.  Most convection, the movement of material is hot air moving upward, not down from the attic to the house unless pressure differences occur (why top opening freezers tend to be more efficient).  Conduction is a function of the cube of the temperature difference if I recall correctly, so minimizing this would be beneficial, which means that cooling a hot attic would be to some extent beneficial in this regard, and keeping surfaces cooler means that they will radiate less energy as well.
Having a light colored roof which reflects more of the light striking it would also help - or just build a shade of solar panels above it :-)  Rich
Put house in the shade for the summer | 12 comments (12 topical, 0 editorial)
